1994 Isuzu Trooper
250,000 MILES • 6 CYL • 4WD • AUTOMATIC
SUPERBIKE909
My transmission is not shifting automatically. The check trans light is flashing as well. It will shift If I shift it into low gear then up shift as I accelerate. If I don't do this it seams like it is trying to take off in 3rd gear and accelerates very slow.
Jan 29, 2010 at 9:49 AM
  • 31,937 POSTS
Hi there, the check light is indication that there is a fault code in the ECU, we need that code to help determine the cause of your problem.
Mark (mhpautos)
Jan 29, 2010 at 9:58 AM
