1993 Isuzu Trooper will it fit
1993 ISUZU TROOPER
KAREN123
1993 Isuzu Trooper Four Wheel Drive Automatic
hi i have a 1993 isuzu trooper and the engines blown (its an import) i have been offered an engine from a 1995 trooper but its out of a manual transmission,my question is will it fit. thanks
May 3, 2008 at 8:57 AM
JACK_SWOGGER
  • 8 POSTS
all engines from 1992 - 1995 are interchangeable. just make sure you don't mix match the sohc with the dohc as you will have computer problems. As far as the transmission... the worst case scenario would be having to swap the bell housing from your old transmission to your new transmission... Don't worry, its not that hard. only a couple of bolts.
Sep 6, 2010 at 8:40 AM
