1993 Isuzu Trooper speedometer repair
1993 ISUZU TROOPER
191 MILES • 6 CYL • 4WD • AUTOMATIC
DWIGHT BOND
How do you remove the speedometer and replace the cable/gear?
Aug 27, 2008 at 3:07 PM
KHLOW2008
  • 41,814 POSTS
Hi Dwight Bond,
Removal & Installation
1. Disconnect negative battery cable. Remove instrument cluster panel and disconnect all switch connectors. Remove steering column covers.
2. Remove retaining screws on support bracket between steering shaft and cluster. Remove retaining screws, pull cluster out and unplug wiring. Remove cluster assembly.
To install, reverse removal procedure.
© 2007 Mitchell Repair Information Co., LLC. Page 1 of 1 INSTRUMENT PANEL -1993 Isuzu Trooper LS
Aug 29, 2008 at 9:29 AM
