1993 Isuzu Trooper oh shyt
MASTERTJ
  • 1993 ISUZU TROOPER
  • 6 CYL
  • 4WD
  • 140,000 MILES
Ok I was driving the car and something popped under my dash. The car stalled out then it started it and drove it home. After that it wouldnt stay running. I jumpped it and started but when I let my foot off the gas it stop running. The alternator is no good either is the battery. So what else would it be?
Sunday, August 23rd, 2009 AT 10:52 AM
  • 31,937 POSTS
Hi there,
Check all the vacuum lines for a leak, run a scan to check for any set fault code, have the alternator repaired and replace the battery, these will let you down when you least expect and need it.
Mark (mhpautos)
Monday, August 24th, 2009 AT 5:33 AM
