1993 Isuzu Trooper High Beam Switch
1993 ISUZU TROOPER
JOHNS36
1993 Isuzu Trooper 6 cyl Four Wheel Drive Manual 251k miles
My 93 Trooper's high beam switch has stopped remaining in the locked position. When I pull back on the switch, the high beams come on just fine, but as soon as I let go, they turn right back off. The lever does not 'click' into the locked position like it used to.
Apr 5, 2010 at 2:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
multifunction switch most likely has failed internally, will need to replace switch.
Apr 30, 2010 at 4:16 PM
