1993 Isuzu Trooper coolant leak
1993 ISUZU TROOPER
159,000 MILES • 6 CYL • 4WD • MANUAL
ARMTDAWG
I just had to pull the tranny because the clutch went out. In the process I discovered that I had a coolant leak behind the flywheel. When I pulled it I found a small hole above the crank. I bought a manual but it didn't show the rear of the engine, so is that a small freeze plug or do I have bigger problems?
Mar 1, 2010 at 12:26 PM
The only way for coolant to come out that side is a leaky freeze plug
Mar 1, 2010 at 12:30 PM
