1992 Isuzu Trooper FUEL PUMP & FUEL INJECTORS
SAMOANTHUGLIFE
I have a 1992 Isuzu Trooper 3.2L V6 engine automatic transmission , it turns over but it won't crank up , i put a new fuel pump and new fuel injectors & plus i changed the relays and fues , the timming belt is good , i get fire from the spark plugs and the fuel is flowing through the fuel rail , but there's no current going through the fuel injectors electrical lines , just like the fuel pump electrical lines , theres no current at all
Dec 4, 2008 at 6:43 AM
  • 75,988 POSTS
Check the ECM fuse 30amp and F-10 15amp if okay test the main relay and fuel pump relay.
Dec 4, 2008 at 7:37 AM
