1991 Isuzu Trooper Starting and dying
190,000 MILES • 4 CYL • 4WD • MANUAL
SHORTSTUFF5
I have a 1991 isuzu trooper 2 and when i start it up it will start with no problem run for a few seconds then die like somebody just turned it off, what would be the cause of this?
Dec 28, 2007 at 7:24 AM
BLACKOP555
  • 10,386 POSTS
does it fire right back up after it dies out or do you have to wait a few hours then it does the same thign again.
if it doesnt start right up does starting fluid or carb cleaner sprayed directly in the throttle body fire it up?
Dec 28, 2007 at 11:52 AM
SHORTSTUFF5
yes it will fire right back up as many times as you want it too until the battery goes dead. A mechanic had mentioned it might be an ignition switch but im not for sure.
Dec 30, 2007 at 4:06 AM
BLACKOP555
  • 10,386 POSTS
try cranking it then manually holding it back just far enough for it not to crank, if it runs change the switch.
when the car starts to die, give it a shot of starting fluid, does it still die?
Dec 30, 2007 at 5:27 AM
SHORTSTUFF5
today i put in the new ignition switch but i did the same thing, it would start up then died. Well me and my uncle was messing around with the fuses and figured out if we pull the engine relay it would start and stay running but if it was in it would start then die. Both of us is kind of stumped what this would be. Also we have no clue what the "engine relay" actually does..... On another note we found out i wasn't getting a charge back to the battery so we determined the alternator is bad which we are replacing tomm. Just out of curiosity would a faulty alternator cause this problem....
Dec 31, 2007 at 2:26 PM
BLACKOP555
  • 10,386 POSTS
not really, especially if it runs when you pull the "engine relay" try a new relay.
Jan 1, 2008 at 2:19 AM
SHORTSTUFF5
well we tried a new relay and it does the same thing. We are kind of clueless now....
Jan 1, 2008 at 8:03 AM
