1991 Isuzu Trooper burning oil
1991 ISUZU TROOPER
VOLCANODEE
Engine Performance problem
1991 Isuzu Trooper 4 cyl Four Wheel Drive Automatic
the engin is useing a lot of oil , oily moisture is coming out the tail pipe , a watery black oily spatter ,the smoke is white also if you open the oil fill white smoke comes out there also. is this rings or head gasket when i first got it it was not so bad but it may have been over filled by two quarts , also its not leaking very much
May 6, 2008 at 2:32 PM
Posted: Tue May 06, 2008 8:32 pm Post subject: 1991 Isuzu Trooper burning oil
Check the condition and level of the oil. If overfill drain it-if not get a compression check both dry and wet method and give me the readings-
Or a cylinder leakdown test-
May 6, 2008 at 4:33 PM
