It blows white smoke all the time when given gas it looks black. also fouling plugs. And rough idle Was told could have whole in piston.
Mar 2, 2010 at 5:37 AM
DOCFIXIT
✓Experienced Mechanic
Compression test will tell any coolant loss? using oil?
Mar 3, 2010 at 3:44 AM
JSNWLCE7720
MEMBER
no coolant loss has oil leak so little oil loss but i dont think its buring it the exausts smoke smells kinda like gas i think
Mar 3, 2010 at 7:57 AM
DOCFIXIT
Is this a throttle body injection? if yes look at injectors while running shine flash light on fuel stream. May have leaking injector spray should be fine mist 360 degree patteren. if you see driping or streaming then inj need cleaning or replaced.
Mar 4, 2010 at 7:39 AM
JSNWLCE7720
MEMBER
if you pull off the numer 3 and number 5 plug wires while running it doesnt change anything even if you pull them both at the same time it runs the same. Could it be the heard gasket blown between two cyl.? The injectors seem to be ok.
