1989 Isuzu Trooper 89' TROOPER
212,000 MILES • 4 CYL • 2WD • MANUAL
JG27828
I Have an 89' trooper that starts up and runs just fine in high idle at cold start however after a minute or two it will slowly give its self less and less gas and stall. If i give if i hold down the throttle it will stay running. I tried adjusting throttle and idler , it just starts in a really high idle and then stalls out. need advice on how to trouble shoot this problem.
Jan 21, 2010 at 10:50 AM
DBIRGENHEIER
Yes, I have a similar problem with a 1988 Isuzu Trooper II 2.6 L (4ZE1) I-TEC fuel-injected engine. Starts easily every time but dies after 5 seconds or so. Replaced fuel pump, inline fuel filter, O2 sensor, checked vacuum hoses. Still no luck. Electrical? Getting frustrated. Does anyone have an answer?
Dec 31, 2010 at 6:15 AM
