Engine Mechanical problem
1989 Isuzu Trooper 4 cyl Four Wheel Drive Automatic
I have an Isuzu Trooper 1989 2.6 fuel injection petrol.
Replaced the head, cam belts and tensioner. Set it all up to TDC but find that the number one piston is on the exhaust stroke, number 4 is on the firing stroke (rockers rocking) I am about to insert the distributor and set it up I have two books one tells me that I set it all up for number 1 piston (as I have done for timing) the other (online) tells me to set it up on number 4 piston ie. put it in when 4 is rocking....I am lost hope you can help
May 7, 2008 at 8:23 PM
