1988 Isuzu Trooper Air Pump
14,000 MILES • 4 CYL • 4WD • MANUAL
CSTRANGE91
When I purchased this vehicle the Air pump was removed, along with all the hoses. What remains is the tube that runs along the valve cover that connects to the head by 4 small tubes that screw in near the exhaust ports. Question. Can remove this and screw in threaded plugs to the head?
Dec 8, 2008 at 5:51 PM
  • 31,937 POSTS
Hi there,
Those plugs are blocking the air injection ports into the exhaust chambers, you can not remove them and run the engine.
mark (mhpautos)
Dec 8, 2008 at 7:27 PM
