1986 Isuzu Trooper grinding sound from the trany
205,000 MILES • 4 CYL • 4WD • MANUAL
1986TROOPER
so when i start my car up you can hear a grinding sound from the middle of the car. when i put my foot down on the clutch it starts to whistle and continue sound like something is rubbing??
Apr 17, 2009 at 5:42 PM
  • 31,937 POSTS
Hi there,
you may have a problem with the ring gear or Bendix on the starter and the noise with the clutch may be the thrust bearing, a mechanic should be able to confirm this if they have a listen.
mark (mhpautos)
Apr 17, 2009 at 7:25 PM
