1991 Isuzu Stylus Acceleration Problems
KMOO4986
1991 Isuzu Stylus 4 cyl 180000 miles
My 91 Stylus with 180k miles (my first car so I'm pretty clueless). A couple weeks ago I was on the freeway and my car stopped accelerating. It would not go past 45mph even though my foot was on the floor. After a couple miles it jerked than began to accelerate again. A couple days later the problem happened again but this time while driving on the street. I stopped at a red light then my car will not go more than 15mph. A couple blocks later with my foot on the floor, it jerked, went to 20mph and the engine light came on. After another stop light it went back to only 15mph and the check engine light disappeared. So far the only work I've had done on the car is replaced the alternator and get a tune up. My mechanic wasn't able to tell me what's wrong but he did say I have to replace the catalytic converter because it rattles. Will that solve the problem? If not what else should I have checked on the car and what type of mechanic do I go to. (my mechanic was from an electrical/ smog place). Thanks a bunch.
Feb 16, 2010 at 2:57 AM
  • 75,988 POSTS
Hi kmoo4986, Welcome to 2carpros and TY for the donation
Replacing the catalytic converter might solve the problem-rattling noise is a sound of loose debris could cause restriction. You can disconnect the exhaust pipe temporarily to rule out the Cat.
Bring it to an exhaust system specialist-such as Midas
Other causes of the hesistation problem could be caused by the following:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Feb 16, 2010 at 6:25 AM
