2007 Isuzu Rodeo Question check transmition warning light !!
2007 ISUZU RODEO
29,000 MILES • 4 CYL • 4WD • AUTOMATIC
SRWARD
Hi
The check trans warning light comes on and the transmition puts itself into 3rd gear. This can be put right if you switch off the ignition and restart the car.
The gearbox will then run normaly for the next half mile or so until the falt happens again. The local isuzu dealer have pluged in their fault reader and are telling me there are two faults. 1 a falty solinoid/valve inside the gearbox. 2 falty throttle position sensor. my question is can the falty throttle sensor cause the solinoid/valve problem to happen. it seems strange that both falts have shown themselves at the same time and at such a low mileage. Thanks
Aug 12, 2010 at 2:50 AM
ROB KANDUTH
  • 10 POSTS
i just bought my son a 1994 rodeo i have been to two shops last one was tsi they where telling me it was the tranny control module well news flass put one in before i came here so i played the game i went and bot another one and wow there i was at the tranny shop again new computer two modules to the tranny tps coil pack crank sensor spark plug wires plugs put new wires from crank sensor to coil and module the code there telling me is computer i think its the tranny selinoid i think this is the biggest pile of crap they ever made no one seems like they can fix them good luck if i find anythig out i will pass it they even told me it was the stereo my son put in the truck i took that out to
Aug 29, 2010 at 8:47 PM
