2004 Isuzu Rodeo Question starting and transmission problems
2004 ISUZU RODEO
CRYVER
Engine Mechanical problem
2004 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic
I think both of my questions are related to some type of control in the motor
they started about the same time and both are random
At times when I try to start the car it just clicks. It will clink some times only once other times several tries before it starts. This is random. I have checked battery, terminals, and every thing else.
second at random times if I start out at a normal rate from a stop the car will halt then jerk like the drive stopped for a minute. If I start out slow then you do not see this. At other times the trans will act like it is slipping as I am driving.
Again both happen at random times. I had a check done by a garage and they said there was an electrical problem but would not give more detail unless I had them do the repairs. I just did not trust them so I am trying to do a online question before i try another mechanic.
Jun 27, 2010 at 9:26 AM
