2003 Isuzu Rodeo Question Oxygen Sensor Issues
109,900 MILES • 6 CYL • 2WD • AUTOMATIC
SPBAKER
I had check engine light & codes for both oxygens sensor heaters. I replaced both oxygen sensors & reset the codes. After a few miles both codes came back. Could the problem be the O2 heater fuse? If so, where it it located? Could the problem be the coolant sensor? If so, where is it located?
Thanks.
May 1, 2009 at 3:32 AM
MERLIN2021
  • 17,250 POSTS
It would help if you could post the actual codes, 02 sensors have half a dozen fault codes associated with them, so please post the codes!
May 1, 2009 at 11:09 PM
