2003 Isuzu Rodeo Question HESITATION
2003 ISUZU RODEO
80,980 MILES • 4 CYL • 2WD • AUTOMATIC
HEYWOOD F CARPENTER
WHEN I FIRST PULL OFF THE CAR ALWAYS HESITATE LIKE IT WANTS TO SHUT OFF, BUT IT NEVER DOES, AFTER A FEW SECONDS OF THAT, IT THEN DRIVES LIKE A BRAND NEW CAR, WEATHER IT BE A STOP SIGN OR A LIGHT
Jul 3, 2010 at 9:54 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 3, 2010 at 10:07 AM
