2003 Isuzu Rodeo Question Fan
2003 ISUZU RODEO
81,035 MILES • 4 CYL • FWD • AUTOMATIC
GCARLOS181
The fan on my rodeo works only sometimes. I get in the car in the morning and turn the fan to high and works fine and then I hit the A/C switch everything fine. Later I get in the car and fan does not come on at all but when I do turn it to high with no air blowing and hit the A/C switch I hear a click but still nothing. I have replaced elec fan fuse and the high and low fan fuses as well as the two small blower fuses and nothing. Can you please help have pregnant wife and needs this fixed soon its really hot outside.
Aug 16, 2010 at 12:44 PM
KHLOW2008
  • 41,814 POSTS
Hi gcarlos181,
When the fan fails to work, give the fan housing some banging with you hands. If the fan starts up, the motor is failing as the carbons are almost worn. You would have to get it replaced.
Aug 21, 2010 at 2:37 AM
