2003 Isuzu Rodeo Question Engine squell
2003 ISUZU RODEO
101,000 MILES • 4 CYL • 2WD • MANUAL
BMONRO
My Isuzu started squealling really loud, and sounds like it may be from the back of the engine. I took the serpentine belt off and started it, but the squeal was still there. It gets better when you accelterate, but never really goes away. I have tried hard to isolate the area it was coming from, but didn't have any luck. Any suggestions?
Feb 8, 2008 at 5:44 PM
ALIGIRL160
I too have been having this problem with my 94 isuzu rodeo. It is the exact same problem that you said. I was wondering if you found out what the problem was. I would very much like to know. Or let me know if it just stopped on it's own. Thanks
Apr 1, 2008 at 3:37 PM
BMONRO
I haven't found it yet, though now I susjpect it is a pinhole in the intake manifold gasket. I have replaced the timing belt, timing belt idler pulleys and water pump, as well as having a cracked exhaust manifold repaired. I don't know what engine you have, but there are some differences between your engine and mine. i will update this reply when I do find the problem.
Apr 3, 2008 at 4:45 PM
