2003 Isuzu Rodeo Question Brake lights
73,000 MILES • 6 CYL • 4WD • AUTOMATIC
ASUNGER2000
Hi there,
When my lights are on my right rear light is dimmer than the left one and when I press on the brakes the r/r light doesn't light up at all. Also, when the lights are off and the brake is pressed the r/r brake light is dimmer than the left on. I tow a boat with this vehicle and in the past I have had some problems with the wiring harness shorting, but it never effected my vehicles lights.
What do you think?
Jan 27, 2008 at 12:39 AM
  • 75,988 POSTS
Better check the wiring harness it could be shorting out from there.
Jan 27, 2008 at 3:57 AM
