2002 Isuzu Rodeo Question Check Transmission light
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
LOSMITH1
I have been having a lot of trouble with mt transmission, I have replaced, 4 transmission, and after I drive it for about 100 miles,the check trans. light comes on, I have replaced the Battery, and the light comes on same way. the transmission shifts fine but the light stayes on.
I got codes 1870 and 0342
Nov 11, 2009 at 2:35 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The code P0342 shows as a cam position sensor fault, but i have no reference to a code P1870 could you re check that one, and i would check the cam position sensor and circuit as well, start here.
Mark (mhpautos)
Nov 12, 2009 at 7:33 AM
