alternator replacement instructions please?
2002 ISUZU RODEO
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMESATSHARP
I have a charging problem that has stumped most of the mechanics I've talked to. It began with a bad alternator, replaced. Then no problem till long trips (3-4hrs) at night with lights drawing more current, battery went dead several times in same scenario. During these times the alternator would seem to overheat and quit charging till cooled.
Jun 25, 2010 at 1:00 PM
BORIS K
  • 836 POSTS
It sounds like you might have too much load going through your alternator. Does your vehicle have any additional consumers like more powerful driving lights or perhaps a sound system installed? It could be that the alternators rated output is not high enough to cope with the additional load created by these additional consumers. This would cause the alternator to overheat . Using a digital volt meter you can test the alternator yourself
To check your alternator please see below links:
and
and
https://www.2carpros.com/articles/how-to-replace-an-alternator
and
https://youtu.be/FTGz0PKIl84
How to replace the alternator:
https://youtu.be/Alf82D1mLj0
Please let us know how you get along.
Cheers, Boris
Apr 27, 2021 at 2:12 AM
