2002 Isuzu Rodeo Question Brake Lights
38,000 MILES • 6 CYL • 2WD • AUTOMATIC
DICKC
The brake lights on my 2002 Rodeo work fine until I turn on the headlights.
When you step on the brakes, while the headlights are on, the tail lights go dark, instead of getting brighter. The center brake light does work with the head lights on, in fact all other lights work; turn signals, hazard etc.
I have checked all the fuses and they are fine. Is there a relay or resistor that could cause this?
Jan 10, 2008 at 6:40 AM
FISHERMAN
  • 937 POSTS
Hello !!
do you have a trailer plug and hitch on your truck?
let us know..
Jan 10, 2008 at 6:46 AM
DICKC
No I don't have a hitch or trailer lights
Jan 11, 2008 at 1:00 PM
FISHERMAN
  • 937 POSTS
Hello !! Here`s the schematic, looks like you have a bad connection or broken wire... check the black wire under center console B8 (that`s the ground exclusively for the stop lights) or the red on the splice (+) .. let me know if you need the schematic big and i will send it to your E-mail.. good luck!
https://images.2carpros.com/forum/automotive_pictures/576_0_1.jpg
Jan 11, 2008 at 1:33 PM
