2002 Isuzu Rodeo Question AM/FM/Cassette/6CD radio
196,000 MILES • 6 CYL • 2WD • AUTOMATIC
TESTAR51
I have CDs in the radio and it won't give them back. How do I get CDs out of the radio?
Apr 4, 2010 at 12:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Take a blank/useless CD and place it about 1 inch deep into the slot. Press the 'Eject' button and gently wiggle the CD around. If this doesn't work, repeat and try to get the blank CD below the the jammed CD, and gently pry the target CD upwards. Sometimes, unusual amounts of pressure may be on the unit, behind the dash itself. Remove the dash unit and try previous steps again.
OR
Get a 1 inch to 2 inch wide putty knife and wrap tape around it with the sticky side of the tape on the outside of the knife. Use a strong tape like Gorilla tape for best results. The knife is typically tapered so that if you wrap the tape tight enough it will not slide off the end
Get a piece of paper and stick it to one side of the knife. Trim with scissors. You now have a thin sticky knife you can slide into the CD player opening.
Insert knife into CD player with sticky side down trying to get it to go on top of the CD that is stuck. Press down gently to get the tape to stick to the CD.
Gently lift up and pull the knife out. Hopefully the CD will come with it. You might try hitting the eject button if it doesn't work the first time...
Apr 23, 2010 at 5:44 AM
