2001 Isuzu Rodeo Question truck hesitating to go
2001 ISUZU RODEO
CRYSTALGOOD
2001 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 162,?? miles
I have a 2001 isuzu rodeo ls 6 cylinder and it is hesitating when you step on the gas until you get up to a certain speed. I have already put a new fuel filter, fuel pressure regulator, spark plugs and boots. Was needing to know if you have any suggestions.
Jul 23, 2010 at 4:58 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 23, 2010 at 5:18 AM
