2001 Isuzu Rodeo Question Fuel guage inoperative
2001 ISUZU RODEO
45,258 MILES • 6 CYL • 2WD • AUTOMATIC
TIM 69
I replaced the tank sending unit and this didn't fix the problem. On the advice of a Isuzu tech I also replaced the ECM located under the hood on the driver's side.
The fuel guage reads empty and the low fuel light stays on even with a full tank.
A tech checked the sending unit and it appears good.
What could the problem be?
Thank you,
Tim
Jul 9, 2008 at 9:04 AM
RPISCI2638
You'l have to get the G.M. dealer or someone with a tech II scanner to flash the pcm to get the sending unit programmed. the sending unit sends a signal to the pcm then the pcm powers the fuel gauge.
Aug 21, 2008 at 11:04 AM
