2001 Isuzu Rodeo Question alternator
2001 ISUZU RODEO
JR5583
Engine Mechanical problem
2001 Isuzu Rodeo Question 6 cyl Automatic
just replaced both battery and alternator(refurbushed) still not holding a charge
Oct 23, 2009 at 4:12 AM
JEEPFAN
  • 135 POSTS
you may have something causing a drain on the system.
check it by removing the negative battery cable and hook a test light to the negative cable and touch the probe to the negative post if the light comes on then there is a draw on the system
Nov 4, 2009 at 1:20 PM
