2000 Isuzu Rodeo Question roaring sound
2000 ISUZU RODEO
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
TRIUMPHMAN
Loud roaring noise when you accelerate and it goes away when you let off the gas pedal Would this be the rear end. It is hard to tell where the noise is coming from. Thanks Wayne
Jul 22, 2008 at 12:52 PM
  • 31,937 POSTS
Hi there,
with this type of problem you really need to be able to hear it. But a few clues are a diff will whine and change pitch with throttle settings, and wheel bearings will howl at a constant rate at speed.
Have a listen and see if that helps,
Mark (mhpautos)
Jul 22, 2008 at 12:57 PM
