2000 Isuzu Rodeo Question No oil on dip stick?
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
NATHAN08T
  • 14 POSTS
My Rodeo has a mild dent in the oil pan but no leaks anywhere I can notice nor is it burning oil. I changed my oil and added 4 quarts then another quart a couple weeks later. I checked my dip stick each time but I could not find any oil on it? Usually when I check A dipstick I can clearly see a thick layer of oil where it should be, but on mine it's almost impossible to see. Is there something wrong, or can I just not read my dipstick?
No, the oil light hasn't ever came on
May 30, 2009 at 5:06 PM
DOCHAGERTY
  • 9,606 POSTS
Fresh oil is often translucent. If the oil pressure light is going out then there is probably oil pressure. I have the same type of issue as I find I cant sit at the computer screen or read the paper without glasses, I just cant see as well as when I was in my 20's and 30's.
May 31, 2009 at 2:35 AM
