2000 Isuzu Rodeo Question erratic idle, running rough
2000 ISUZU RODEO
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIM_466
vehicle starts ok but may idle erratically. when driving at slow speed the tach shows erratic rpm.when you stop at a light or slow to take a turn engine may cycle from approx 800 rpm down to almost 0 on the tach and sometimes stalls.when in park and warm idle can also be very erratic.
Jan 28, 2008 at 10:13 AM
BLACKOP555
  • 10,386 POSTS
Check your IAC module, change the fuel filter, plugs, and wires. also clean out the throttle body and EGR ports, that should solve it and are all normal maitnance procedures.
Jan 28, 2008 at 10:42 AM
