2000 Isuzu Rodeo Question Engine Light
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHOLTZ2000
  • 6 POSTS
I have a 2000 Isuzu Rodeo V-6 Automatic. The Check Engine Light has been on for a long time, but the car was running fine. A test revealed a faulty EGR Valve. I replaced the valve, reset the light, and it came back on. I replaced the valve a second time, and the light came on again. Any suggestions?
Jun 10, 2009 at 11:54 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Please post the code in P0xxxx format this will help in diagnosis. And will advise
Thanks for donate
Jun 11, 2009 at 1:59 AM
CHOLTZ2000
  • 6 POSTS
[quote:b9495ed13b="Docfixit"]Hi
Thanks for donate[/quote:b9495ed13b]
Jun 11, 2009 at 2:16 AM
CHOLTZ2000
  • 6 POSTS
What is POxxxx format? How do I do that? Thanks
Jun 11, 2009 at 2:18 AM
DOCFIXIT
  • 18,828 POSTS
Go to an Auto Zone have codes read from computer.
Jun 11, 2009 at 2:21 AM
CHOLTZ2000
  • 6 POSTS
The P Code is P0401. Thank you for any advice.
Jun 12, 2009 at 8:16 AM
DOCFIXIT
  • 18,828 POSTS
Check all wiring look for chaffing also when you had EGR off did you clean passageways and check for blockage in pipes? Aslo a faulty MAP can set code. and any exhaust leaks can set.
Hope this helps
Jun 12, 2009 at 8:49 AM
CHOLTZ2000
  • 6 POSTS
Thanks very much! Checked for blockage already. Will give your other suggestions a try. Have a great weekend!
Jun 12, 2009 at 10:49 AM
CHOLTZ2000
  • 6 POSTS
The Map Sensor fixed the problem! It was easy to install and saved me a lot of money from taking it to our mechanic!! I really appreciate the advice.
Thank you and have a great day!
Jun 21, 2009 at 11:16 PM
DOCFIXIT
  • 18,828 POSTS
Great news glad to be able to help Thanks so much for letting me know often times I never know if I've helped
Jun 22, 2009 at 4:41 AM
