2000 Isuzu Rodeo Question Brake light problem
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
NEBRASKA_CHEVYMAN
2000 Rodeo has a brake/tail light problem. Brake lights work fine until the tail lights are turned on. When the tail lights are on and you push the brake peddle, all the reap lights go out with an exception of the center brake light in the rear window which works fine. Also, the cruise control won't work IF the head lights are on. Also, if the head lights are OFF, the dash lights will come on when you step on the brake. I suspected a grounding problem so I added a ground from  the chassis ground to the negative (-) tail light/brake light wire. It didn't help. Can you help please? Thanks....
Feb 17, 2008 at 12:46 PM
DANIGIRLVA
Hi nebraska __chevyman
Did you find the answer? My 97 Rodeo has the same problem, I've tried many things with no luck. Would appreciate benefit of your experience :)
Thanks
Mar 18, 2008 at 10:09 AM
NEBRASKA_CHEVYMAN
Yes...We found the problem...FINALLY :*)
Believe it or not, it was a bulb causing all those symtoms I mentioned. I will never understand how the one defective bulb could cause all this grief but it did. I suggest you change all the tail light bulbs and "PRESTO" the problem will be cured. Let me know how you come out.
Lynn
Mar 18, 2008 at 11:13 AM
