2000 Rodeo has a brake/tail light problem. Brake lights work fine until the tail lights are turned on. When the tail lights are on and you push the brake peddle, all the reap lights go out with an exception of the center brake light in the rear window which works fine. Also, the cruise control won't work IF the head lights are on. Also, if the head lights are OFF, the dash lights will come on when you step on the brake. I suspected a grounding problem so I added a ground from the chassis ground to the negative (-) tail light/brake light wire. It didn't help. Can you help please? Thanks....
Feb 17, 2008 at 12:46 PM
