2000 Isuzu Rodeo Question
COBRA34
Engine Performance problem
2000 Isuzu Rodeo Question Two Wheel Drive Automatic
when i start the isuzu it s hard to start,you have to turn the key and push the accelerator and works fine but if you turn it off then you have to do the same thing over again,and some times it stalls i think is the gas pump pressure.
Jun 15, 2008 at 11:05 AM
KHLOW2008
  • 41,812 POSTS
Hi cobra34,
More likely you need to check the fast idling and idling system.
Might be a TPS problem too. Is there any check light indicating while driving?
Jun 16, 2008 at 1:28 AM
