1999 Isuzu Rodeo Question won't stay running
162,000 MILES • 6 CYL • 4WD • AUTOMATIC
NAOMI
My truck dies when I take my foot off the gas and now the oil smells bad like gas and it is smoking on the passenger side at the back. I've replace the spark plugs, TPS sensor, Mass Air Flow Sensor. The PCV valve is good and the Idle Air Control Valve is good. Any ideas?
Jan 25, 2008 at 10:38 AM
ZOLO6321
I have a 1999 isuzu rodeo 6 cyl 2 whl dr and at 230,000 miles mines did the same thing, the problem was the fuel pump had it replaced and it solved the problem, also the rodeo have so many sensors on it try having all of them checked. still having a few idling problems with it, but the 1999 rodeo did have a few recalls you know.
Mar 28, 2008 at 1:57 AM
