spark plug gap and replacement
1999 ISUZU RODEO
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
HANSDAKIN
Hello would you tell me what the spark plug gap is 6?
Thank you
Sep 29, 2010 at 4:57 AM
WRENCHTECH
  • 20,761 POSTS
Here is a guide to show you how to install the spark plugs correctly with the spark plug gap - Plug Gap 1.0 - 1.1 mm (0.04 - 0.043 in)
https://www.2carpros.com/articles/how-to-change-spark-plugs
Sep 29, 2010 at 5:01 AM
CHRIS AGUAYO
the boots on the sparkplug wires didnt come out with the wires is there a special tool for this problem and where can I get it
Feb 12, 2019 at 6:55 AM (Merged)
CHRIS AGUAYO
[quote:6ffcc4df62="chris aguayo"]Engine Mechanical problem
1995 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 170000 miles
the boots on the sparkplug wires didnt come out with the wires is there a special tool for this problem and where can I get it[/quote:6ffcc4df62]
BOBMCCLURE
Where are the spark plugs located?
MERLIN2021
  • 17,250 POSTS
If you don't see them, chances are you have Coil On Plug system, each plug has it's own coil, unplug it twist and pull up, and the plug is under it, you will need an extesion to reach it!
