1999 Isuzu Rodeo Question Moving shift lever
1999 ISUZU RODEO
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
PETERLINDSTROM
As per the instruction from Isuzu if you are having problems moving the shift lever from P while hitting the brake with the engine running, then move the key switch to ACC position also move the shift lever from P to N position and start the engine. Why?
That is the problem I am having
Peter Lindstrom
Aug 31, 2008 at 3:31 AM
SKTHOMAS
Hi Peter,
Did you get that problem fixed? I have a 1998 Rodeo and I am experiencing the same problem at 180000 miles; unable to move shifter out of park with the engine running or powered. I can however turn the vehicle off and put in nuetral to start.
Please post the fix.
Dec 1, 2008 at 4:09 AM
PETERLINDSTROM
Thanks for the mail.
Yes the problem is a grounding problem down at the bottom of the console where the shift lever is located. In other words it's about an electronic issue rather then a manual one. There is a part that can be ordered but it takes 2-3 days to get, so rather then wait they grounded the electrical unit to the bottom of the chassi. They have to remove the instrument panel so the job takes a few hours but is cheap and easy to fix by grounding.
Let me know if you have any questiosnm.
Peter
Dec 2, 2008 at 12:28 PM
