I have a '99 isuzu rodeo 4x4 that has some problems with the front-wheel drive part (the "rear") when engaged. I have no problem engaging it into 4x4 and drives pretty well, even at higher speeds. However, when i turn the wheel hard around a corner, epecially if its a tight turn then the front rear begins to shake. If im at a stand-still for instance and turn the wheel ALL the way to say, for instance, get out of a parking spot, it will shake and freeze up to the point where it will not even move(almost like being tide to a pole or something. In fact, the first time i experienced this, i was at a gas station pulling away at cut the wheel tight to get out and thought i was hitting a curb or something like it was hindering me from moving. Because of this, i only use the 4x4 when absolutely necessary, like in a snow storm and when i won't have to cut the wheel in tight places. Any suggestions? Thanks, Jay.
Jun 20, 2009 at 10:20 AM
