1998 Isuzu Rodeo Question Timing belt
1998 ISUZU RODEO
290,000 MILES • 6 CYL • 4WD • AUTOMATIC
FABIOT
If the timing belt happens to snap on my Isuzu, will the engine blow or burn out, or will the belt simply require replacement.
Thx fab
Jun 23, 2010 at 2:42 PM
  • 31,937 POSTS
Hi there,
Valve damage will normally occur with a broken timing belt, a comp test with the new belt fitted will show if this is the case with your engine.
Mark (mhpautos)
Jun 23, 2010 at 2:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the V6 is a non-interference design engine, so no damage will occur if it breaks just replace belt..for the 4 cylinder style though it would damage motor..
Jun 23, 2010 at 2:50 PM
FABIOT
Thank you very much! That's what i have read but wanted reassurence from an expert. Its nice to know that i can drive and not worry. I cant afford to replace motor components if timing belt snaps . ill wait it out and replace when i have a few dollars.
fab.
Jun 26, 2010 at 12:31 PM
  • 31,937 POSTS
Hi there,
Try and get the belt done sooner rather than later as even if there is no valve damage with this engine, if it fails there is a good chance that it will strand you and this can happen at the most inopportune time.
Mark (mhpautos)
Jun 26, 2010 at 6:20 PM
