1998 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 170K miles
OK you guys! I fixed my car with out your help. There are 2 drain plugs @ bottom of Trans. Pan.
I opened both and drained off 3 QT of ugly brown fluid. I mixed up 3 QT of fresh DEX III with a bottle of Lucas Trans. Fix added. My son pumped in the mix
with a niffty (LARKIN) tranfer pump I found while I held the nozzel tight against the high port. Plug was replaced and problem solved. Before very rough shifting and no OD. Now, drives like new. Total cost was $28. Next time my son comes home I will drop the pan & replace the filter as I now know I can add fluid. I should change my log-in to "NO GUTS NO GLORY" and I should get my donation back as I did this only on my 40 years experience of working on cars.
SPONSORED LINKS
Thursday, March 19th, 2009 AT 8:59 AM
