1998 Isuzu Rodeo Question IDLE
1998 ISUZU RODEO
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
BING797
WHY MYCAR IS IDLE UP HIGH
Aug 4, 2008 at 2:00 AM
BLACKOP555
  • 10,386 POSTS
since its idling high first thing i would check would be for vaccum leaks, you can do this buy using a piece of fuel line and listening one end while probing with the other, when you find a leak itll make a sucking sound.
the easier way would be with a smoke test or you can use a can of carb cleaner and spray all gaskets, hoses. when you find the leak, the idle will change.
Aug 4, 2008 at 3:28 AM
