1998 Isuzu Rodeo Question how likely
NISWONGERJOHN123
  • 1998 ISUZU RODEO
1998 Isuzu Rodeo Question 6 cyl Four Wheel Drive 97,000 miles
my suv's timeing has jumped how likley is it that I damaged a valve and is there any way to tell other then a pressure test I don't have the tool for the pressure test
Thursday, June 10th, 2010 AT 7:11 PM
Its an interference engine -try using a compression gauge-do you hear any type of noises on the valvetrain-meaning the cylinder head/s
Thursday, June 10th, 2010 AT 7:23 PM
NISWONGERJOHN123
Yes it sound's like a rapid tapping noise on the drivers side top of the engine does that mean it's a bent valve is so how would you fix that
Thursday, June 10th, 2010 AT 8:38 PM
You need to remove the cylinder heads to identify the problems
Thursday, June 10th, 2010 AT 9:41 PM
