1997 Isuzu Rodeo Question Everything shuts down when acceler
131,000 MILES • 6 CYL • 4WD • AUTOMATIC
JBLOXHAM
Driving at normal speeds or from stopped and then accelerate quickly - RPM's go to about 4,000. Everything shuts down and then comes back up - battery, brake and 4-wheel lights come on and stay on. The battery voltage then goes to maxed out. If I then come to a stop and try to go again the engine will rev but I don't go anywhere. I have to turn the car off and back on to get everything back to normal. Help
Jan 16, 2008 at 11:07 AM
FISHERMAN
  • 937 POSTS
[quote:452696cad3="jbloxham"]Computer problem
1997 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 131000 miles
Driving at normal speeds or from stopped and then accelerate quickly - RPM's go to about 4,000. Everything shuts down and then comes back up - battery, brake and 4-wheel lights come on and stay on. The battery voltage then goes to maxed out. If I then come to a stop and try to go again the engine will rev but I don't go anywhere. I have to turn the car off and back on to get everything back to normal. Help[/quote:452696cad3]
hello !!
Check the voltage at your battery and see if the altarnator its working right could be that the regulator its not working right and the voltage its fluctuating big time!
check that first and replace the alternator if faulty because it could "kill" your ECM.
good luck!
Jan 16, 2008 at 1:36 PM
