1996 Isuzu Rodeo Question fuel pump
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
HDFLTSFATBOY
I recently got rear ended on my 96 Rodeo, Minor body damage. After the hit the car sputtered and stop running. I figured it s the fuel pump, So i replaced it with a new pump. Now the car would run for 10 to 15 minutes then it would shut off and would not fire up until it sits for awail then it would do it all over again.
Jun 5, 2009 at 2:03 AM
HDFLTSFATBOY
I have solve my problem. I checked all the wires from the relay box from the left of the engine compartment to the right of the engine compartment ( driver side ). When i got hit, it jerked all the connectors loose ( molexes ). This is common on all Rodeos and Amigos. Hope this will help somebody else.
Jun 6, 2009 at 3:09 AM
