1996 Isuzu Rodeo Question fuel
1996 ISUZU RODEO
176,000 MILES • 4 CYL • 2WD • MANUAL
DOGHOUSE1376
truck wont start fuel pump working and proper pressure but when you turn over it doesnt come out of injectors
Apr 3, 2009 at 5:59 AM
JAMES W.
  • 2,394 POSTS
The injectors are feed 12 volts constantly with "key on". The ECM "grounds" the injector to make it fire. With key on, check for 12 volts at any injector connector. If no voltage, start checking fuses.
Apr 3, 2009 at 6:39 PM
