1996 Isuzu Rodeo Question Fan is not working.
150,000 MILES • 6 CYL • 4WD • MANUAL
BLEUSTEEL
The vehicle starts and runs just fine, the fan switch does not operate the fan. The Fan is mounted underneath the glove compartment and I have removed and bench tested it and it works. There is a blower relay under the hood, that also tests out ok. The Heater/Blower relay was just replaced and the heater fan still does not work.
Isuzu indicated to me when I got the relay that they do not have a warranty on this unless you Purcase a new Heater Blower at the same time.
Any Ideas?
Dec 4, 2008 at 2:59 AM
  • 75,988 POSTS
Find the blower motor resistor pack behind the glove box-check the thermo fuse in it could be blown -if it is the blower won't come on. Let me now
Dec 5, 2008 at 12:50 PM
