1996 Isuzu Rodeo Question Drop in oil pressure.
1996 ISUZU RODEO
NELSON213213
Engine Performance problem
1996 Isuzu Rodeo Question 6 cyl Two Wheel Drive Automatic
After driving for a while my oil pressure needle drops to zero whenever I stop. When I start going again and when I am driving the needle goes back up and is fine. But as soon as I stops again the needle goes down again. I can put it in neutral and rev the engine and the needle goes back up but as soon as the rpms go back to 1000 or idle the needle drops again. What can be the problem? I also have a small leak in one of the lines but it only leaks like one to 5 drops whenever I turn the car off.
Mar 8, 2010 at 9:22 AM
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump or engine bearings
Mar 8, 2010 at 10:08 AM
