My apologies. I thought I had made it clear for you to check the fuses/circuit breaker/relay. The diagrams are to show you that these parts are responsible for the power windows to work properly. if one of them is bad, the system won't work.
If you have early production model (May and earlier), check these and make sure that they are working properly:
Dash fuse box (left side of the instrument panel)
1. Fuse #7 (10A)
2. Power window circuit breaker (30A)
Right side of instrument panel, above kick panel
3. Power window relay
If you have late production model (June and later), check these and make sure that they are working properly.
In dash fuse box
1. Back up, turn circuit breaker CB-15 (15A)
2. Power window circuit breaker CB-27 (30A)
In left kick panel
One or more of the three things that I asked you to check may be faulty.
May 11, 2009 at 3:58 PM
